I'm starting to look more at using my ADA MP1 rack unit to record some guitar parts.
I've got an acceptable home recording setup, driven by the Apogee Ensemble interface, which is great for home use.
I'm currently using a Kemper plugged into the Apogee via SPDIF, but could also just use the left/right out into channels on the apogee.
(just for context o you know what's used on the apogee already)
What are the options and potential pitfalls to using the MP1 to record into the apogee ? should I look to just take a feed out, disable the pre-amp on the input on the apogee, or should I look at something like an Strymon irridum and feed the mp1 into that and then feed that into the apogee for a more 'amp simulated' sound ?
I know
@digitalscream has done something similar with the MP2 so I'm curious to my options and understanding the impact of the,
Advice appreciated.
The simplest option is what I did - straight from the line-out on the ADA into a line input on the interface. Then IRs, and job done.
I also use it with a solid state power amp (Harley Benton GPA-100), into a cab at reasonable home volumes, with a supercardioid mic in front for ambient noise rejection. That works surprisingly well, too.
If you monitor direct it will sound awful as there’s no cab emulation.
A hardware cab sim would allow you to monitor a cab emulated signal, but would cost money.
Try the software plugin method first.
Ebay mark7777_1
However...I'm assuming I could get a two notes hardware device like https://www.andertons.co.uk/guitar-dept/guitar-pedals/cab-simulator-pedals/two-notes-torpedo-cab-m-plus-pedal and load the IR's into it, then just put that into the recording interface zero latency with the same good IR's that wall of sound seems to provide.
If your pre-amp has a 'Speaker Emulated Line Out socket, try that.
