2 Audio Sources, 1 Pair of Headphones
Hi,
I was hoping someone could help me out with some setup guidance please.
I (re)started playing guitar this time last year, and have been using Rocksmith as my primary way to play along with songs.
This involved guitar - rocksmith cable to laptop - laptop to big speakers. Easy enough.
Now, I am playing the Rocksmith programme still connected to the speakers, but separately playing my guitar into a Boss ME-80 multi fx, then amp. I MUCH prefer this setup, as the sound is so much more authentic.
I just set the volume on my amp, then change the laptop volume to suit.
However, due to moving house, I will now not be able to play loudly and will need to use headphones.
Is there a solution so I can have the laptop and a separate audio supply (the guitar amp) come into the same set of headphones?
Again, I would set the amp to a volume that I like, then alter the laptop volume as and when needed.
I have just bought one of those Fender micro amps, if that is of any use for this problem.
I bought that for a separate scenario, but thought I'd mention it in case it is relevant/ a solution.
I also have a set of Sony XMH4s, if they could help solve this problem.
I'm not great with tech stuff.
Many thanks in advance.
  • droflufdrofluf Frets: 3878
    Does your amp have a “line in” socket? That’s what I use; so plug guitar in normally and the connected computer to line in and both sounds come out through speaker/headphones.
  • Oh, it's as simple as that?
    Well my current one doesn't have that, but I will gladly use that an excuse to buy a new toy!
  • Winny_PoohWinny_Pooh Frets: 7868
    If you can a get a line out from the micro amp then buy a mini mixer and you can blend that and any other signals in. That way you can have laptop into it too and put multiple things into big speakers without faff.
  • steamabacussteamabacus Frets: 1276
    Sorry if this stops new toy buying but ....
    You can plug the line out from the laptop into the AUX IN socket on the ME-80. Then monitor from the PHONES OUT on the ME-80 or through your guitar amp.
  • @steamabacus ;
    Yes, you're totally right. That works perfectly. Thanks so much, cant believe I didn't work that out myself.
    And, £200 to spend on other toys now. Cry Baby, here we come
