SOLD Bright Onion Stereo AB
All priced to include P&P and assuming buyers covers PayPal fees or bank transfer
****** ALL BELOW SOLD *********A Trio of Bright Onions – All Sold
All in excellent, unmarked condition,
more pics here.
SOLD Stereo AB (ex GavRichList!) £25 SOLD
Like thisThis is a stereo AB switch that enables you to select between two stereo outputs that are routed from a single stereo input. The pedal can also be used in reverse.
SOLD – AB with Passive Volume £25 – SOLD
Like thisThis is an AB switch with the A or B inputs going to the X output. There is a volume pot for the A input, which comes in handy when you have two guitars that you use on the same amp, but one has a hotter signal than the other.
Sold Blender Looper £50 soldOld version of thisThis is a blender looper pedal that enables you to blend your dry signal with a parallel wet signal. For example if you have a delay in the pedal's loop you can use the level knobs to set the perfect level of delay and dry signal.
HP Core
Full working order. Deregistered ready for new owner. No box unfortunately but an Eventide power supply is included.
In excellent condition, just one small chip on the side, bottom edge. Rubber feet are missing and has had velcro on the base (some residue remains).
Loads of pics hereSOLD £250 posted in the UK, assuming buyers covers PayPal fees or bank transfer
Also blender sold
