I have flux, me and flux are an old friend after making thousands of tattoo needles.
Sometimes if the tracks are vulnerable and it's really crowded you are better off cutting the old component so each leg can be removed easily with no damage to the track.
I use a decent braid to clean up after removing the old component the trick is don't attempt to slide the braid unless there's plenty of heat on it .
Then I would use leaded solder to put the new one on
