HOW DO I WIRE A COIL SPLITTER? A PHASE SWITCH?
The design of EMG active pickups doesn’t allow access to the individual coil outputs from the pickups. As such, it’s not possible to wire coil taps or pickup phase switches in the traditional manner. We do provide a number of alternative accesories to help you simulate some of these tone mods.
To get a split coil sound out of a humbucker we recommend the EMG 89, which contains both a humbucker and single-coil in one pickup switched via an included push/pull pot.
The EMG PI2 Phase Inverter actively inverts the phase of an EMG pickup giving you a true out-of-phase effect, controllable by a switch.
Instagram
A DPDT format switch governs the interconnection of the various coils for the two modes.
On the older hard-wired examples, it is possible to govern the coil combinations via a multipole Superswitch. The caveat is that this can introduce noise as contacts are made and broken.
