Today I'm embarking on my first rosewood fretboard removal to replace a snapped truss rod.
The neck has a poly glitter finish which I'm desperate to retain as much as possible
![](https://i.imgur.com/25PnTVG.jpg)
![](https://i.imgur.com/LrWNFTR.jpg)
![](https://i.imgur.com/qFyipoR.jpg)
I've taken it upon myself to score along where I think the board meets the maple so when it comes to steaming it off there'll be as little damage to the finish as possible.
I'm hoping to pull from the hive collective here on wether to remove the frets before taking the board off or after, the rosewood does look fairly thin especially for a Westone.
Does keeping the frets in hinder or enhance structural integrity?
thanks for the space and time.
Just make sure you score and score again on that finish.
The most important bit if planning to reuse the board is to clamp it flat once its off... it will want to curl up
Instagram
Also you might be able to put it back and keep the original frets, saving the work of re-fretting it as they look to have plenty of height?
Frets in makes sense, I've seen the use of a steel rule between iron and frets before for "better heat distribution" but that's possibly overkill as I'll be going as slowly as possible.
I've scored through to wood all way round but I'm not 100% sure I've hit the join, definitely at the head end where I can see rosewood meeting maple.
I have a set of clamps and a flat surface ready for the board.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
here goes nothing!
came off really clean and not a single fouling of the neck finish, phew.
same again with the fillet strips?
I really was hoping i could replace the single action rod with a dual action but don't think it will be possible with the contoured channel, am I wrong?
And how wide?
the neck is 17mm at that point, minus fretboard obviously.
I don't own a router
I'd need to find someone to do the rout for me though, wouldn't want to practice on this
A couple of concerns:
I couldn't fully straighten the neck with the old rod, it wasn't far off but not quite enough for my liking. Will I encounter the same problem with like for like?
Was the problem that the rod was starting to rust and was stuck fast in the channel, should a single rod have any movement in there?
At this point i would be considering filling the channel to reroute for my chosen 2 way rod. But obviously yahts the trickier way forward
Instagram
I guess I could shift the anchor up a bit and tweak the bend in the rod but unsure how much thread I'd need for a new nut.
it is quite a slim neck and I don't know if a dual would fit at the headstock end
