PCB £5 +p&p
A couple of hours for the PCB and god knows how long for the awesome finish - is it a transfer? Have a wow - hope that helped.. not sure it did.
I know, there are three transistors and a small number of other small parts too, but you can stripboard it in not much more than the footprint of the pots. It's basically a "development model" with most of the values you would want to experiment with replaced with pots.
No, I am not offering to build one .
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
You must still use a nut on the inside of the switch though, or you'll probably separate the bushing from the switch body when you tighten the outer one - just make sure it's down as far as it will go.
If youre triggering remotely you can gain yourself some space by leaving the footswitch out.
