You may find it goes greener due to the colour of the wood, so you might want to add a touch more blue to the stain. Unless you have offcuts to test in its hard to predict... also, the oil will yellow it a bit
Instagram
Even if you have no offcuts of the exact wood just get a feel for the stains on something first, even if it's a bit of pin or plywood.
You don't need a lot to make the grain pop.
2. Brown Stain base, with water and a touch of Yellow Stain, mixed in separate plastic bottle.
First mix applied to the whole body.
Second mix applied just to the edges for a gentle burst affect.
