Also bear in mind that most of the tonal characteristics come from the preamp, not the power amp - although the power amp can have a larger effect on the dynamics.
Especially if you don’t need stereo. Most dedicated power amps are stereo, and rack-mounted.
There are a huge number of fairly cheap valve amps which will work perfectly well. All you need is an FX loop/power amp input, or even a very basic clean channel (eg Orange Rocker 30).
Preamp pedal i.e Kraken
Then you'd be landed really. Hmm things to ponder
