Is the bridge a Fender type with freedom to rock slightly when the vibrato is used or fixed like a Tune-o-Matic?
The pivot plate on budget tailpieces has the sharp edges and deformities that you would expect from a punch machine. Tidying these up improves matters.
Do the strings go out in the same direction as the last arm movement? If yes the problem is most likely at the bridge end, if they go out in the opposite direction it’s at the nut end.
The bridge is a likely cause if it isn’t rocking, and the buzz stop will make it worse.
How do you set up a Jag to only pitch down? That's a new one on me. Guess you can do it by leaning the bridge back or forth in its thimble so it's touching it? If so, avoid doing that as step one.
I'd advise making sure you've got at least 10s on it. My VM was fine with 10s (though I'd got hold of a USA bridge for a tenner or so which was a slight upgrade).
Once it's tuned up to pitch, wiggle the bridge and make sure it's in the middle of the thimble, at a flat angle to the guitar, if that makes sense.
In fact, that's just made me think, have your bridge posts slipped? Are the grey pointy ends poking out the bottom of the chrome section or have they recessed inside? That might mean your bridge isn't "rocking" properly within the thimble and might be causing the slipping. Obvioisly you'll have to detune and take the whole bridge out to check this. I've found the adjustable posts can wobble themselves back up into the recess on certain bridges. Adjust them back out again and maybe loctite them in place once they're back in place.
This is all quite hard to explain without oodles of text. Does any of that make sense?
Does the budget tailpiece on the Squier have the lock mechanism?
I suppose that it might be possible to attach something on the underside of the tailpiece baseplate to physically prevent upward wobble.
A literal interpretation of the expression "downward only" is that it describes the movement of the bridge rather than the tailpiece. If the entire bridge were positioned with its resting position leaning towards the tailpiece, it could only rock towards the fingerboard. (This suggests a complete misunderstanding about how the vibrato system works.)
Time for photographs, methinks.
https://www.axecaster.co.uk/index.php?main_page=product_info&products_id=647
I also bought a Staytrem arm and collet.
Someone with a better engineering brain than me might well know why that would make no actual difference but I'm sure there's some kind of benefit gained by trem spring tension being in a "floating" position... Or rather, I'm sure I've heard it's not that great to have one part of the trem touching another like that (I've used the locking button before and it definitely works without "full extreme" adjustment like that).
I'm rambling. Managed to get myself some 8.5% beers today. Apologies!
