Mu-Tron Octave Divider- octave up / down in series or parallel? (with circuit diagram)
english_bobenglish_bob Frets: 5158
edited May 2021 in FX
Question for people who actually know what's going on inside those little boxes we like so much. Thinking about replacing my Mu-Tron clone with separate octave up and down pedals for flexibility- are the octave up/down circuits in parallel or in series in the Octave Divider?
Circuit diagram to hopefully make it easy:
MU-TRON Octave Divider Octave Divider Guitar Pedal Musitronics
  • english_bobenglish_bob Frets: 5158
    Anyone?
  • ICBMICBM Frets: 72410
    The link isn't working, but I'm almost certain they will be in parallel - it wouldn't really work otherwise. You can't duplicate that with separate pedals, unless you use a third mixer pedal.
    Thanks @ICBM ;. That's what I thought was more likely.
    I use an ES-5 switcher so technically I probably could duplicate the parallel routing but it would involve dedicating two loops to octave pedals that I don't use that much, which seems a bit excessive.
  • cathodynecathodyne Frets: 24
    In case it might be helpful, I’ve read that the octave up section is a Dan Armstrong Green Ringer circuit.
