Very small power supplies with 2x12v any recommendations?
chromatunachromatuna Frets: 371
I am plotting a tiny ‘throw in a bag’ board ( have a PT Nano) with a few essentials, probably just three effects plus a tuner. Snag is I want definitely one 12v connection for my Carbon Copy, the option of another would be handy too. Any suggestions?
This is the truth from hillbilly guitars!
  • personalnadirpersonalnadir Frets: 355
    Cioks 4 looks like it will cover pretty much everything
  • chromatunachromatuna Frets: 371
    Thanks @personalnadir ;
    I maybe should have picked up the Adam that was recently in the classifieds here for £50
  • ICBMICBM Frets: 72420
    TGI Power Box
    https://www.dawsons.co.uk/234661/tgi-power-box-micro-power-supply
    I've actually got one of these going spare which you could have for next to nothing, but it's missing the 18V supply - as usual with these mini ones it's more correctly described as a distribution box... the *supply* is the bit you plug into the wall. 18 centre-negative 3A supplies (which I think is the requirement) seem to be quite hard to find.
    Thanks @ICBM I’ll have a look at that one although to be honest I would rather have an integral transformer than a wall wart
  • eogeog Frets: 40
    Strymon Ojai has 5 outputs, two of which you could set to 12v (or 18v)
  • eogeog Frets: 40
    Sorry, should have said Ojai R30
    Me too, which is why you could have had it for next to nothing :). I could convert an old laptop power supply I've got to run it, but it's about four times the size of the distribution box so I haven't bothered yet...
  • robinbowesrobinbowes Frets: 3046
    18V 3A Switching Power Supply Charger 18V3A 5.5*2.5/2.1 mm AC DC Adaptor https://www.amazon.co.uk/dp/B01JFTCEP0/ref=cm_sw_r_cp_api_glt_fabc_HHYN3P8MZEFQPX1FT9GZ
    Tip positive.
    Unless you get one that you can open up the casing and swap the connections... which is rare, most of them are glued now.
    I suppose you can replace the plug, but it's a bit of a bodge.
  • prowlaprowla Frets: 4928
    I've just bought a CIOKS DC-7, which is very small and also versatile; every output is 9/12/15/18V switchable and at 9V it does 660mA.
  • Mr_ClawMr_Claw Frets: 94
    Truetone CS6? That's got 2x 12v switchable ports and a 2x 18v. They can all be switched back to 9v. Pretty small too.
    https://www.andertons.co.uk/guitar-dept/guitar-pedals/pedal-power-supplies/truetone-1-spot-pro-cs6-low-profile-power-brick-w-fully-isolated-outputs
    edited May 2021
    Thanks for the suggestions folks, I am quite surprised how much even a small decent power supply costs but I guess if a handful of components overdrive can be £200 then maybe I shouldn’t be, the PSUs probably better value. I shall see what pops up used
