I have never really understood why they’re so desirable.
Good to know! I've not changed strings on my LP jr yet, look forward to dropping the bridge on the top.
as for the faff of drilling and resetting (if needed - that's what I cam here to find out - you'd think there'd be a load of adaptors out there) ... the "faff" is irrelevant it's a matter of "low premium time" vs "high premium time" - on stage with a band and audience waiting (either just to get to the end or with anticipation) is what I'd class as "high premium time" so I wouldn't drill and fill the post holes whilst on stage I wouldn't even want to go "threading the needle" to fit a string in the tiny gap betwixt bridge pickup and wrap-over... whereas in "low-premium time" where it's a toss-up between watching a repeat of Antiques Roadtrip with SWMBO or ducking into the gaarage - well that's a no brainer - I'd do either at that point
Another option might be a stopbar with a ridge and string grooves (a plain one won’t work, the strings will slide about) and a second tailpiece behind it - Gibson did this on the cheaper non-reverse Firebirds with vibratos.
It's annoying that they're unavailable new, and the prices people have started to ask for them are getting silly - but still probably less than if you have to pay a professional to modify the guitar.
Even more frustratingly I have most of one in my parts collection! But it's missing the string anchor bar and one of the saddles... otherwise I'd be happy to sell it to you (for a lot less).
Instagram
Being able to assemble a 445 from parts would be awesome - are the saddles any different from TOM saddles?
https://www.thefretboard.co.uk/discussion/206631/fs-gotoh-510ub-wraparound-bridge-in-chrome#latest
Instagram
Instagram
Doesn't matter if you don't use the wobble arm. The installation is three wood screws.
There don't seem to be any in the shops at the moment either... hmm
Turn 2 large brass plugs to fit in the existing bridge post holes, with a large enough area on top to position 2 brazed threads to accept an ABR, or Nashville, in the correct position.
Some sort of trapeze attached to the strap button, and Bobs your uncle.
I could do it, if I had the time and equipment, and it would be bespoke to the instrument.
But I can't, because I don't, and a wraparound has it's own charms.
Tonequest report did their own search for the best sounding LP, and a wraptail came out on top.
