[/quote] thanks guys :-)
I was thinking of giving Scumback's reboxed version of the Alex a try too, heard loads of people praise the old Alex, shame he never exported them.
The best way to do it is to set the volume roughly with the attenuator *first*, then dial the amp in for that volume level and attenuation. If you do it that way round you can usually get better sounds at lower volumes - not the same as at high volume, but good. Use the attenuator as part of the dialling-in process and not as a quick fix afterwards.
