Okay, so I have one of these:
http://store.highlyliquid.com/products/midi-cpuI've never done anything with it, because of a lack of a need and an enclosure. But now I'm thinking about my pedalboard, and can see this space along the second row which would fit perfectly for a DIY amp controller. My Diezel D-Moll supports midi. All I need is the ability to send three program changes - 1, 2, 3 - from three footswitches.
Enter this bad boy:
http://www.digikey.co.uk/product-detail/en/1455Q2201/HM1172-ND/773847It looks like it might be a slight pain to work with, as it has no bottom only side panels, so I'd have to slide the PCB and switches in from the side. Might be a bit fiddly but the dimensions are good.
It looks to be roughly 220mm (L) x 125mm (W) x 47mm (H)
http://www.hammondmfg.com/pdf/1455Q2201.pdfSince I only need three switches that should give me enough clearance between the switches. What do you think?
A much better option for a far better price too -
http://spiratronics.com/diecast-box-222-x-146-x-55mm.html
