Some advise heating the fret first to soften any glue used to hold it in place. Then use fret pullers to get between the bottom of the fret and the fretboard, working them along the length of the fret to gradually lift the fret out of the slot.
The main risk is pulling too hard/fast and chipping the slot as you pull the fret out.
Proper classical/Spanish guitars have a flat fingerboard. This could be a pain to chord on - even in open tunings.
Do you think the potential damage would generally be cosmetic or might also spoil the playability of the guitar? I'd have thought cosmetic which I'd be a lot happier to risk but just checking.
I wonder if I'd be able to get a grip with normal pliers to avoid having to buy a specific tool.
Cheers for the advice. I'm not really sure what I'd want to play on it to be honest. There's a recording of Erkan Ogur playing what I assume to be Turkish style music on a fretless classical guitar that I've always really loved and that's what's made me want to try it out so the DADGAD getting a bit Arabic sounds appealing (might be showing my ignorance if Turkish music has no relation to Arabic music - I'm thinking it's geographically close).
From a quick Google, though, there doesn't seem to be anything in the way of mass produced budget fretless guitars so converting a normal fretted one is my only option really. I'm imagining I give up in frustration due to it being so difficult to play but I still really want to give it a go lol.
You can try some snips, but the end needs to be ground flush so they go under the fret easily.
Heat is essential for reducing chips, but this is one of those jobs where you really don't know how hard its going to be until you start pulling.
Sometimes they pop out easily and you could get by with minimal tools. Other times you find every single one is a pain and having the right tools is the difference between destroying the board or not..
On an easy board, you can slide a knife under a fret end, wiggle gently and it just pops out leaving a clean un damaged fret slot and board
On a hard one you need tape either side of the slot to catch chips. Heat, a blade to start lifting the fret, and snips pullers to gently walk it out. Then thin superglue to immediately stick back the chips that happen on every one
Instagram
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Sounds like it might not be something to DIY.
Hadn't even thought about the truss rod/neck bow issue. Given Feline's reply it seems it won't necessarily be a problem though.
Re: the filling of the slots, I was kind of thinking it would be okay to just leave them unfilled - would that not be feasible? Might be a silly idea, I don't really know the first thing about fretless guitars.
ICBM's shop is close and I also have a lot of faith in a place called The Guitar Workshop from previous experience so I think I'll get one of them to do it if I do go for this rather than having to buy a tool and then still risk messing it up.
Thanks again
You start at one end of the fret with a soldering iron and with the gutters, moving across the fret .you slowly wedge the fret out, You will need a good flat sanding block to refinish the fingerboard. You can use the dust, from the fingerboard with super glue to fill the fret holes. Classical guitars don't have a truss rod, because they don't need them. Removing the frets will not change that .
Unfilled fret slots leave pairs of parallel edges right where your fingertips should be holding the strings down against the fingerboard. Glissandi will be punctuated by clunking noises as you slide across the gaps.
On fretless instruments, the strings have to be fingered bang on where the frets used to be rather than between.
To begin with, you would need to put practice and concentration into achieving accurate intonation. Eventually, you build sufficient confidence to mess with intonation and create interesting effects within a band context.
Those wire cutters will need to be ground as flat as possible on the end first, or the fret will be all the way out before you can get the cutters underneath.
The idea the neck may bow without frets seems to be the opposite to what happens during compression fretting, you use a wider tanged fret wire to force the neck straight
Instagram
Reminds me I have a 60s hofner classical with a severe neck bow I need to correct at some point
Instagram
I recently used compression fretting on a Strat neck that wouldn't come straight. It worked a treat.
I have used an electric unfretted ebony board neck with pre cut fret slots and filled it with maple laminate strips & superglue.
Due to the tension needed in your case I'd get a luthier to put a new fretless thicker ebony/rosewood onto a decent guitar.
Or if you want to go electric then look here for a budget unfretted neck:
https://www.boobooguitars.co.uk/collections/guitar-necks
