SS Practice amps - cube convert!
samzadgansamzadgan Frets: 1471
Today i spent about 3 hrs trying various practice amps. To start with I had my heart set on a Marshall CFX30 and was also keen on the orange crush range. I didn't really want the fenders and definitely didn't want a cube...mainly based on looks.
So i tried and found the following:
- Marshall: absolute arse in every way. Felt very flimsy and sounded horrible. With the treble rolled all the way off it had a high shrill character to the sound that was pain full to listen to. The headphone sound was better, more lowend but not great.
Verdict: 1/10
- Orange: much better than Marshall, but nothing to right home about, and the headphone sound wasn't great. Still suffered from being very bright, and i couldn't take the treble knob past 1 but at that level it was ok.No effects on this model.
Verdict: 5/10
Peavey Rage: cheapest of the bunch, nice clean and overdrive sounds. Had nice function around voicings, switch between modern, vintage and stack, which had an overall eq shift. No effects on this, just 2 channels.
Verdict: 7/10
Fender Mustang: nice clean tone, better than the rest. The amp models, not sure if accurate, but at least gives some nice versatility on overall tone. The OD tones were ok, but i wouldn't use them. Headphone tone was ok at best. It has a bunch of effects too.
Verdict: 7/10
Laney LX35: Surprisingly good for the price. The cleans are very nice and the distortion can get very heavy indeed with out the the highend shrill. Also has an overall tone change the the XTR switch. The headphone wasn't great but could live with it. It had no effects, but has an external speaker jack, which could be useful.
Verdict: 8/10
Roland Cube: Fuck me! In every single way better than the rest. The improvement in the sound is so much that i cant use the other amps to compare against it. Firstly with the Eq set to 12 o'clock, it sounded warm, clear and just perfect. The cleans are beautiful and OD channel is great. Admittedly i settled one of the amp models, which i probably wont change, but it sounds so good i don't need to change it. The headphones sound amazing, again cant compare to the others. The one thing that bugged my was the footswitch, but then i did a little research and found there is a 6 button footswitch available as well (GA-FC).
To be honest i didn't go to try the cube to buy it, i just wanted to see what the hype was about before i bought the laney...but oh my!...was i surprised!
Needless to say, Verdict:...well cant really do it justice with a rating out of ten compared to the others...if I was to give a rating out of 10, then it would be a 10...with the other scores halved at least.
For reference my criteria was purely an amp that sounds good with or without headphones, effects not a requirement, but if so, i wanted some kind of footswitch. I don't plug mu amps into my computer and I'm not into the whole downloading software etc so, some of the other amps functionality in this department were ignored.
Finally, this has been written over the bus trip home so all grammatical and spelling errors should be put down to the bumps on the road!
  • GassageGassage Frets: 31591
    edited August 2014
    I have been saying this for years. Truly amazing things, esp the cleans.
    Have a wisdom.
    And I hope you enjoy your new job at Roland ;)
  • JalapenoJalapeno Frets: 6464
    Wisdom added !
    If you can stand it, take a look a Chappers' mystery amp video on YouTube.
    Feedback
  • KebabkidKebabkid Frets: 3413
    edited August 2014
    Nice one and Cubes are great. I have the Microcube, the Cube 60 and Bass Cube 120XL. Was it the Micro Cube that you got or which model?
    TIP:On the Acoustic Channel, and with an acoustic, take a line out to the PA and you have a great acoustic preamp & fx. 2 weeks ago I played a whole function with a Micro Cube lined out and just used the fx and models- it worked !!
  • ICBMICBM Frets: 74495
    Must admit I didn't like the ones I've played, they all sound quite artificial to me. The clean channel on the bigger models isn't too bad - it's plain analogue solid-state, rather than digitally-modelled - but I wouldn't say better than any other solid-state amp of similar power, maybe not even as good.
    I like the old JCs too - I'm not anti-Roland or anti-solid state at all. Even the little JC-55 2x8" sounded much better than the Cube, to me.
    i got the Cube 40xl...should have really got the 20...but something about bigger made it better!!  ;)
    I jammed with my band mate last night at my place...not drummer, just two guitarist...and it sounded great. The distortion is a little too tight for my likings, but i was never going to get that fuzzy distortion from any practice amp.
    now i need to buy the 6 button footswitch, and I'm all set!
    @samzadgan - what amp model are you using for your distortion and what style or sound are you going for? The Tweed is good for break up stuff and crunches well with humbuckers but for more singy leads and thicker distortion, the Metal amp is better, but with both models, I don't have the gain beyond 12-1 o'clock.
    @kebabkid i started using the metal amps and didnt like them that much. I settled on the Dynamic Amp...which is really good. Gain is on about 2-3 o'clock.
    I read through the manual today and saw that tweed = bassman...so tonight thats the first thing i will try out.
    The kind of music i play is doom metal...which is really thick loose distortion/fuzz...some may call the tone muddy...but i like a bit mud!
    The Dynamic should work well and it's pick sensitivity feature is great!
    All the best with your new amp!
  • 57Deluxe57Deluxe Frets: 7406
    edited August 2014
    Fender Super Champ XD - miles better!
    <Vintage BOSS Upgrades>
  • BlueingreenBlueingreen Frets: 2716
    I like the Microcube a lot, think it's great value for money and wouldn't hesitate to recommend it as a practice amp.  But it has its limitations. I upgraded to a Yamaha THRC, and while you could argue about whether the price difference is justified, there's no question the Yamaha is a better sounding amp, particularly on the clean settings.
  • xSkarloeyxSkarloey Frets: 2962
    My son now has my Microcube but I still borrow it back from time to time.
    It's like a Swiss army knife of guitar gear. I wouldn't say it's perfect but what it has is adaptability and convenience in spades, and that casts all other reservations aside for me.
  • Love the microcube. Absolutely indispensable piece of kit.
    Am seriously considering a cube 80 for an all-in-one gigging solution when I don't want to take a valve amp and pedalboard.
    Feedback
    /\ ...sounds more Roland rat...
