Hi, looking for some help on wiring in my latest modding project, as I can’t find anything on the web that helps.
I have rewired my tele to broadcaster wiring as per the broadcaster with blend diagram on the link below.
https://www.seymourduncan.com/blog/tips-and-tricks/three-cool-alternate-wiring-schemes-for-telecasterI fitted a humbucker in the neck a la Keith Richards, and am loving the tones I am getting from it, however as usual my need to tinker and potter has found me contemplating whether I can split the humbucker with a spare push/push switch I have lying around to get single coil sounds also.
Is this possible with the wiring as per the above link?
Thanks
All you need to do is use the push-pull to switch the coil split connection to ground, or if that leaves the wrong coil of the humbucker on, to the same pickup hot connection on the switch.
Vintage routs are the same depth all the way along.
Alternatively, use a special five-way selector switch and the circuit from a Fender Fat Telecaster SH. The coil splitting is automated by the selector switch.
