Photo as shortcut on iPhone 7
RockerRocker Frets: 4983
We got our Covid Digitsl Certs and I took a photo of it using my iPhone.  How do I create a shortcut to display that photo on my phone.
I Googled this and there are lots of tips but none on how to display a photo.
All help appreciated, thanks
Nil Satis Nisi Optimum
  • boogiemanboogieman Frets: 12365
    I’ve had a play round with my iPhone and I don’t think it’s doable, unless you want to use the photo as your wallpaper. You could mark the pic as a favourite (press the heart icon), then it’d go into your favourites album so there’d be less photos to wade through to find it.
  • WazmeisterWazmeister Frets: 9540
    This.
    Save as a 'favourite' in your Photos
  • welshboyowelshboyo Frets: 1815
    edited July 2021
    Not sure if 7/older IOS will allow you to do this but I use the "save to files" option - save it to your phone's location and then use the Files App to get to it - best way I've found - I'm 12Pro/IOS 14 btw
    I also use the same for PDF's etc etc
  • skullfunkerryskullfunkerry Frets: 4174
    Similar to marking it as a favourite, you could create a new album in your Photos app and save that photo to it with nothing else. Advantage of doing this is that as you add more favourites it won't get buried.
  • FunkfingersFunkfingers Frets: 14430
    Save the photograph as your screenshot. (In Photos.)
    Every time the handset is activated, the COVID certificate image will be displayed until the pass code, finger print or facial recognition unlocks it.
    Make certain that all text in the photograph is clearly legible. In screenshot mode, it is not possible to zoom/expand.
