Building a new board - stuff needed!!
moz91moz91 Frets: 38
Putting together a small, basic pedalboard on a reasonably small budget, could do with the following If anyone can help!
  • Basic power supply (Ideally one of the old JohnnyShredFreak knockoff's of the Diago PowerStation)
  • Boss GE-7 or similar
  • Dual-latching footswitch for amp channels & reverb (lost the one that came with my Blackstar). One of the teeny mini ones would be cool...
  • Basic overdrive/boost, nothing too fancy for now... Any sort of TS would do just fine
  • About ten right angled mono 1/4inch jacks
  • TU2, polytune, korg pitchblack etc... - Any sort of basic, cheap tuner!
  • BidleyBidley Frets: 2952
    I've got a Dano Transparent OD V2 and a Marshall 2 button stereo jack footswitch, modded with two LEDs that run off 9v battery or DC power. I could do those and chuck in a few of my spare patch cables (at least 5, maybe more) for £35 delivered?
  • MXR 6 Band EQ (basically new) and a Polytune Noir going if its any interest?
  • moz91moz91 Frets: 38
    Bidley - I'll take the footswitch and patch cables, pm me!
    Does the mxr 6 band have a volume slider or is it just 6 eqs? Could really do with the volume slider (ala ge7) as its gonna be a lead boost! Polytune looks cool, though!
  • No the MXR doesn't have the volume but as you boost the frequencies the volume goes up anyway. I planned on using it for a lead boost to add some midrange but found the KOT worked better for my rig. I will say it's a hell of a lot quieter than the GE7 though. Unless you get a modded one they are noisy as hell.
  • John_AJohn_A Frets: 3775
    edited September 2013
    Korg Pitchblack ltd edition in white - brand new £30?
    Boss OS2 very versatile and good sounding pedal with OD and distortion modes £20
    or £50 for the lot including 5 quality patch leads
    Postage included
  • TC polytune - 45 posted.
    Also I have three Line 6 M5 pedals, and only use two so I have a spare one of those too I can probably part with.
    Thinking an mxr 10band eq might be the way to go...
    If you really do need the volume it's a much better choice than the Boss. Do bear in mind though it's a 24v power supply. Bit of a pain.
    True, that would be a ballache... 18v isn't it?
    Suppose I could just get a mid boost from a decent ts9 and use a microamp int loop for a volume boost...
  • Sorry yes it is 18v. TS will give you a mid boost indeed. Probably the right one too. If you want a clean boost for the loop the best one you'll find is the Rothwell. Either the F1 or the Atomic. The only boost I found that is so transparent you can use it on acoustic. No colour to it whatsoever.
    That's definitely an option. Ive got a microamp somewhere, ill see what sort of boost it gives me int loop.
    John A - I'll settle for that tuner and a few patch leads!
    drop me a pm and well work out the details :
  • monquixotemonquixote Frets: 17891
    I've got a Route 66 which will sort you for drive and boost.
    I've got the Boss GE7 if you want it. PM me and we can talk.
    Now sorted for OD, Tuner, Foootswitch, EQ and a few patch cables.
    Still need a power supply, a few right angled jacks, and maybe a basic delay pedal
    Geepers - How much you willing to let the M5 go for?
  • geepers0677geepers0677 Frets: 119
    Check your PMs dude.
    Anyone going to sell me a power supply and/or a cheap delay???
    Actually I might have that mxr eq you know... Pm me a price!
    Bump for a delay, PSU and maybe an eq pedal!
