This one is a conundrum.
Long story short, there was ground hum coming from the below board, tracked it to the Mimiq at the end.
Stuck
an isolation transformer (great things) on the secondary lower output,
problem solved. The Mimiq Has it's own dedicated outlet on the PSU.
Now I initially missed it because there's 2 keyed gates in my amps FX loops which are very effective.
However
this only seems to have appeared since setting up in my new house as
this wasn't an issue without the gates in my old house.
Why might this have materialised now? Fault in the pedal? Something else?
Considering
my recent thread on anal cable management for my new gear room, some
may suggest that as a cause. It's worth pointing out that if I drop the mimiq out
and come straight of the bright onion AB/Y, there's no hum.
Always good practice to have some sort of lift or isolator if you're doing fx-loopy stuff anyway, IMO.
The Bright Onion has the second output ground-isolated, I'm fairly sure.
