It would cut through the chrome though and wouldn't be as nice a finish as one plated after engraving
Maybe not but it might be worth asking.
*edit* Ha - I didn't realise the original pic was one of theirs!!!!
You can cut a cost by supplying your own design , but most companies won't take on a one off or they will charge you loads for it .
Laser would cheaper option for sure . CNC takes longer to set it all up , thus more expensive .
Regards cutting through the plating, I presume it is possible to etch/ engrave polished stainless steel, such as the Callaham neck plates or similar?
Would it be possible to design the artwork and then produce a 'mask' for a polished neck plate (either plated or polished stainless) then shot blast to produce a matt effect where its shot? I've no experience, just throwing the idea out there.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
* Hamer SS2 & T62
* Music Man Luke 1
Please drop me a message.
* Hamer SS2 & T62
* Music Man Luke 1
* Hamer SS2 & T62
* Music Man Luke 1
