Complete noob when it comes to this - got my ID Core so can do the playing & recording through that, have other guits & amp too, but in terms of the bits in between, what do I need so that 2 of us can either play or play & record together?
I was looking at the millennium hp4 but i don't think that does headphones which is a bit of a must or even if thats the right thing tbh, can anyone help?
Also, can just be playing together thru phones, rather than recording if that affects budget, please make it "disabled/not working" budget friendly if you have any suggestions.
Thanks
scroll down to bottom, there’s also an alto £25
So is this right - these take your guitar lead as input, mix the 2 signals and send the dual signals as one to each amp as an output, so you can just use the headphone output on each amp? Sorry to be a pain, just trying to get my head around how the setup works.
Live amps:
2 channel recording interface
2 guitar amps mic'd or one direct (but playing through speaker) one mic'd
Millennium Hp4 to split your audio interface to two headphone outs to monitor what you are recording onto only, live sound will come from amp in room.
If you want silent recording w no latency:
You need to have two modellers or digital amps
Normal outs from modeller goes into interface.
Amp Headphone outs go into a 4 channel mono mixer into two mono inputs.
Into stereo channel of same mixer or mono input 3/4 goes your audio interface outs.
Then mixer out gies into HP4 for your 2 headphones.
I have an IDC 20w mentioned & stagg 30w fx both headphone capable & not sure how to go about being able to join the 2 for a silent jam if thats even the right way - 1st eleccy rig(s) u see after acoustic, so just seeing if its possible.
So, i guess i need to check the stagg, if not get another modeller & do what u said latterly?
