Greetings again folks,
I finished up wiring oyr latest build, consisting of 3 mini humbuckers (2-core wiring), 2 tone controls (A500k pots with 22nF on bridge and 15nF on neck+mid), one volume (A500k) and a 5-way blade switch on upper horn.
The 3 leads coming off tge 5-way are routed back through the body to the control cavity with their shielded part soldered together.
The humbucker wires, going to the 5-way do not have their shield soldered to anything at the 'free' end but are touching the other shields giving continuity.
All solder joins seem good, though may not be in the correct place.
My problem is threefold, and I would be grateful for any trouble shooting pointers or suggestions why this might be happening.
1 - volume works, but almost on-off at very earliest part of turn from full volume.
2 - the tone controls hwve very little effect, though it is present.
3 - There is little difference in sound between the pickup positions.
Many thanks for reading this, and advice given.
Adam
It explains the reality quicker and clearer and allows us to spot things you may not yet know to notice.
Personally I use a linear pot on the volume control, makes for a more effective gain control when used with drive pedals, so that may be a thing to try.
Following schematic diagram for CRL two-pole selector switch but using Japanese YM-50 switch.
Hold on whilst i upload to imgur.
Interestingly when i unscrewed the 5-way to take a photo, i plugged it in and the problems seem to either have gone or vastly improved. It had occured to me that a short somewhere might be the cause - perhaps the photo's will make it clearer.
Cheers,
Adam
The control cavity (there is a break in the ground lead between pots near the short orange wire)
https://i.imgur.com/BhvwlBQ.jpeg
5 way switch in-situ
https://i.imgur.com/wE4Fml2.jpeg
More 5 way switch
https://i.imgur.com/NrCMsg2.jpeg
https://i.imgur.com/EWy4SZ3.jpeg
https://i.imgur.com/1zJXro6.jpeg
https://i.imgur.com/Zb7qc6p.jpeg
Thanks for looking,
Adam
1) the small, metal covered item associated with the Gibson Les Paul Deluxe and some old American Epiphone semi-hollow guitars?
Cheaper examples of the latter can be wound so excessively hot that it is difficult to get much tonal variety across the bridge, middle and neck selections. They all sound heavily compressed and only really work well with high gain overdrive.
If you have a meter with Ohms range measure from pickup hot to ground and see what you have ?
Where I've fitted silver hook-up in stuff like a 335 I've covered the braid with shrink wrap when it gets near the switch to prevent it inadvertently earthing anything it touches.
The 5 way switch is pretty exposed and looks well-soldered but I'd still wonder if the sliver-braid might touch it in that small space.
These are the pickups, only difference is they have a foil top on mine. Fitrebird style.
Mini Humbucker SunBird — home (sunbearpickups.com)
The braided wire is simply either from the pickups, or hookup because of the long cable runs through the body (because the switch is on the upper horn) and I wanted it shielded without the faff of copper foil or conductive paint. I suspect that normally you wouldnt see it on a 5-way because they are not usually used in humbucker equipped guitars (which rarely have 3 pickups) and the normal single coils have 2 cloth braided wires rather than centre+shield of humbuckers.
Adam
I recently assembled a reverb pedal and left the led off as I couldn't be bothered to do it just then ... for the 335 I eventually took the wiring out and bought transparent heat shrink for the braid.
I've kinda stopped trying to get things perfect on the first go, but I do treat myself by going back and sprucing stuff up later
I know what you mean about not first-time perfect, and I will need to go back and do a proper setup (though gotta say the action and relief were nearly spot-on at first stringing, as was intonation. I would like the action higher, but am wary of raising the wraparound bridge further.
Adam
Is there any cavity shielding paint, especially around the jack? This sort of partial short (it can't be a full one as the output would be muted entirely) is often caused by that, rather than metal touching metal.
Cheers,
Adam
I guess I should do some digging online, lol, to see if I can find a diagram.
I even take this to the extent of determining the best order in which to solder the parts into circuit.
I've had my tokai 335-alike since 2005 and as I'm a lefty it came 'meh good enough' brand new, a bit buzzy, reversed cheap pots and a set of okay pickups... many pickup, pots and capacitors later it sounds as I always wanted it to...
Early on I had to learn to pace myself, not bite off too big a project, estimate conservatively, have somewhere safe to store incomplete projects and so on. Today's task is "check power I'd getting to the engineers thumb compressor I made" that done it will be put together and placed in storage for audio probing or whatever...
It feels a bit like the prisoner who went on to be The Count of Monte Cristo... slowly slowly.
I totally do that order thing as well, but mainly because I'm a bit clumsy and find it hard to solder properly if I can't get into the cavity easily. Push-pulls/push-pushes are especially bad for that... you really need to solder the bit that's hardest to get at first (usually the pot lugs), or it can be an absolute nightmare.
(I haven't tried those new CTSes yet.)
