Another day, another query from my latest build. This is not so much of a cause for concern as a "will this improve things" question.
I have used one of these Wilkinson wraparound bridges on my latest build, and following earlier advice, have achieved pretty good intonation first time,
Wilkinson Wrap-around Bridge for Les Paul Junior / Jnr, etc, Badass (northwestguitars.co.uk)As I have the bridge with a bass-side offset, the strings do not follow quite a straight path over the channels on the bridge, leaving the forward (pickup side) edge at a slight angle.
The forward edge has a slight lip to it where the string channels exit, which is easily seen in close-up.
With this bridge, would it be worth/advisable to file down this lip, or is it required, forming the saddle?
Cheers,
Adam
The PRS stoptail has no lip.
Instagram
Adam
e.g. On Fender Jazzmaster and Jaguar guitars, the strings fan out slightly from the tailpiece anchor point towards the saddles.
On Gibson Junior and Special guitars with a smooth wrapover bridge, the strings traverse the bridge surface at a diagonal relative to the edges.
As an aside, does your sig "be seeing you" have anything to do with an American folk singer?
