Done some further investigation and the Woden transformer is the interloper i.e. a replacement. WEM used the larger transformer in all the photos of these amps (10 examples) that I could find. Pretty certain that it's a Dagnal Transformer and they seem to still make that transformer albeit with a 4, 8 16 ohm taps now. They list it as a 10watt transformer but the dimension are identical in every way to the old one in my WEM. Not much work to change the transformer so may go for it, cost is £30, so not too bad.
Final question, is the Zobel network in the signal path?
Well the resistor is 10x lower.
Just been sourcing a replacement transformer for the old WEM and realised that the Woden that's currently in it has a 14k primary. Should be 8k for a pair of EL84's. It's a single out at 4 ohms and I've been running it into 16ohms!
So is that 3 steps away from where it should have been? i.e. to get 8k approx. on the primary I should have been running it into 2 ohms? Can't have been doing the valves any good, fortunately they are old Mullard's and I didn't play the amp too often.
Compared to the other amp with the original transformer, this one did sound very dull and lower output, I'm assuming the totally wrong output transformer values accounts for this?
