Greetings folks,
A couple of nights ago I decided it was finally time to sort the nuts out on a few guitars I'd built that worked but were in the could-be-better-I'll-get-around-to-it-sometime category. One of these was the double-neck uke I made a couple of years ago. Nut's nicely fettled (and saddles shaved back so action as good as it's going to be), and time to re-string.
However, it just reminded me how much the synthetic strings seem to stretch and stretch and stretch - each day I was needing to tune up about 1-2 rotations of the tuner post. I dont think it's because the uke top is about to pop off/implode either.
So, what's the trick to winding a new nylon string so that it is neat, like an electric string is, and not taking up the full tuner post with wraps?
Cheers,
Adam
Depending on your instrument, putting the palm of your hand on the bridge and pulling the end of the string before feeding it through the tuning peg will help as well, but I'm yet to find a way that makes the wraps as neat as anything else, I always end up with more turns than on the G and C string.
I don't think it's the strings - Aquila baritone uke and Martin half-size classical should be 'good' enough, I'd have thought.
And as yet, this is not a gigging instrument - though it does naturally play into George Ezra's Shotgun
Adam
