Where do you get your replacement soldering iron tips from...
..and are they a standard size? I bought a generic station a couple of years ago and it works just fine I just need a chisel tip as the one I have is not quite meaty enough for pots. The only detail I can find in the manual states: 900M Series Tip Out Diam 6.5mm.
Also what size would you recommend? 2.4mm?
