Hi all,
Recently got an Iridum. So far so good, not done extensive tests with it but I was pretty familiar with what it does.
However, now I'm also aware of it's limitations. Currently I'm running a Boss Mustang GT100 via line-out to the Iridium into my Apollo interface (just using the amp as a multieffects really). As good as this is, I can't help but feel the Helix Stomp XL would give me essentially that, but in a smaller footprint and with many more effects able to run at once.
My questions are- have you guys found the Helix amp models match up to the (albeit limited) emulations on the Iridium? And do you find the Helix fuzz and ODs react well in comparison to the real things? I know you can't adjust the input impedance on the dirt 'pedals' on the HX FX, can you do this on the Stomp XL?
For me the Iridium sounds pretty good with very little work.
I can’t get a sound I like out of Helix products but that is user error and cause I can’t be bothered doing all the EQ’ing etc it needs to sound good.
