blimey, if our whole top floor is 70% at the moment, god knows what it’s like in summer !
“The month with the highest relative humidity is November (86.79 %). The month with the lowest relative humidity is July (70.78 %).“
i.e. that summer is less humid than winter
Most of the UK, most of the time, has humidity in the safe middle range. Some particular locations may require extra care. Most (not all, "most" of the yammer-yammer about humidity comes from the States where they have triple whammy: their climate has extreme swings because of the unusual continental geography, they like their guitars a bit on the flimsy side, and they heat like crazy in winter and cool like there was no tomorrow in summer.
im in the south east, many miles from the coast, and our 4 rooms upstairs in a modern 18 year old house are all 70% , the en-suite is 80%.
ok, we dry clothes in a couple of the rooms in autumn / winter, and put towels over the bannister after showering, But none of that sounds any different ti the rest of the population.
Anyone any suggestions? Presumabky I can’t buy a plug in dehumidifier and use it in the en-suite ?
I can't see the point in dehumidifying the en-suite (unless you keep guitars in there). But I don't like the sound of those black spots. It rather sounds as though it is lacking ventilation. Do you think the en-suite arrangement is driving up the humidity in the rest of the house?
It strikes me as a situation needing an openable window and/or a more powerful fan. Where does the existing fan exhaust to? It should blow the wet air outside, of course, but I've seen dodgy installations where the exhaust fan just blows into the ceiling space - i.e., not getting rid of any moisture, just spreading it around a bit.
this is for cigars (where they also care about humidity for storage) but water doesn’t care if it’s a vintage Martin or a Corona hand rolled in the thighs of a Cuban virgin https://www.famous-smoke.com/cigaradvisor/how-do-you-calibrate-a-hygrometer
I don’t think it needs to be 100% accurate; if you know that it reads 5% high you can then track changes in humidity which are not as important as the EDIT absolute displayed values.
it’s quite funny with the 2 guitar cases being more humid inside ! I dried them both out with the hair dryer, got them down to 10 - 20%, aired them a bit, and put the guitars inside for a few hours. Took them out later that afternoon and the readings inside back up to high 60s. That was interesting I thought.
