I own this MIM Telecaster with 4Gen Fender Noiseless PUPs. I am planning to install a 4-way switch and reverse the control plate.
My understanding is that this should be pretty simple, will probably need to ground the neck pick up and change wire in one of the pots which is likely to be too short when I reverse the control plate.
BUT...this is my first time doing this kind of work, I've never soldered anything before and I want to avoid screwing things: Any practical tips I should keep in mind? Anything that might go wrong? Will a 4-way switch work with the Noiseless pick ups? Any resources that have helped with these kinds of mods before?
Also, what would your suggestions be for sourcing a new switch and cable? While I'm in there, any other useful mods to consider?
Sorry for the vague questions, but any input would be great.
https://electricpickupartist.wordpress.com/2020/06/05/fender-n3-noiseless-tele-pickups-baja-wiring-conversion/
so it seems the noiseless have a separate earth for the cover - so can have a baja mod
I have never been a fan of the reversed control plate idea. On some Telecasters, there is a shallow portion in the control cavity between the selector switch and the first pot. This will obstruct the electronics if you try to fit them in reverse.
I have the neck set up for jazz and the bridge for ice pick
I've got the baja mod on my tele and I like the new setting but there's a volume drop that might make it challenging to use in a band situation.
Yeah @tanihhiavlt , exactly, I also find that tend not to switch pick ups that much, but definitely play around with the volume and tone knobs.
I guess part of this whole process has to do with making the instrument feel my own, by working on it and changing things around...good point about the shallow cavity Funkfingers, I'll have a look
Thanks again to both of you for your input!
