Playing via In Ear Monitors
TeetonetalTeetonetal Frets: 7803
Looking for a bit of guidance on this one...
I have just joined a party band , it's a 10 piece funk rock band with a full horn section. The band is currently using in-ear monitoring as they have found this the easiest way for them to rehearse in a small space.
At my audition, I took along my Pleximan, and they miced up the  cab, giving me a monitor box with me + band mix. Issue was, that given how small the practice room is, I had to have my amp running pretty low., which was not ideal. For the rhythm stuff it was fine, but solos lacked any kind of sustain.
So  now I am thinking about the best way to handle this, my thought is that this is the ideal setup for a modeler, such as the L6 Helix,  now I do have one, but it's really the heart of my home setup and I do not want to be unplugging and plugging it in again on a weekly basis. For my upcoming rehearsals I will do this , but I need another long term solution. I can't afford a 2nd helix!!
I need a clean, crunch and solo sounds, along with delay, compressor, tremolo and wah
For live, they mic everything up and push the whole band through the PA, so modelling seems to be the answer...
I'm considering:
Get a HX stomp and add it to my pedal board. I guess I could link it to my Es5 and control it via midi to switch between clean and dirty sounds? It's not got enough switches to use standalone.
Go all pedal and get an IR loader and Cab Sim pedal to stick at the end of my board, so they can take a line out - not exactly sure how this would sound clean. I have a Gurus dd1959 which I could use as amp sim, but the clean would not have a preamp...
How have you tackled setting up for In Ear?
  • FarleyUKFarleyUK Frets: 2411
    Could you use Helix Native for your home setup...?
  • @FarleyUK , yes from a pure FX and sim POV, however, I have the helix setup as an audio box, I'm using all the FX loops, plus I have a synth connected - it's functioning as a mixer, audio interface and outboard DSP...
    The other approach would be to replace the helix at home with something else.
  • MusicwolfMusicwolf Frets: 3655
    How hard is it to unplug and re-plug your Helix?
    In the studio mine sits on the floor in front of the rack and it has power (IEC), USB, MIDI, main out, 2x sends, 1xreturn and guitar in.  That's 8 connections to break / make which takes me less than 60 seconds.
    The key is all the connections are at the Helix end so, when I take the Helix away, all the cables are left.  The other trick is to mark the connections on the back with little colour coded dots (the little self-adhesive paper dots that you get from the stationers).  This also makes life easier when I'm hooking stuff up at rehearsals / gig.
    Time how long it takes you to disconnect and reconnect than multiply this by the number of times pa you expect to do this and put a value on this using whatever your current salary works out at per hour.  Then compare this with the cost of an alternative setup.
  • @Musicwolf It's no that it's difficult as such, mine also sits on the floor and connections are accessible. I am wary of constant unplugging and plugging in.
    I was ideally looking for a setup I can leave in the practice room (the space is rented exclusively by the band) so walk in / walk out.
  • Could you just get a pod go and use it as an amp/it loader and just run your pedals straight into it ? Or buy a second hand helix lt and just use that ?
  • RolandRoland Frets: 8714
    There’s a benefit from performing, rehearsing, and practicing using the same equipment. It sounds similar and any effect settings, such as timed delays, are the same. I use my AxeFX that way. Unplug the morning of a gig, and re-plug the day after.
    On stage, with IEMs and everything going through the PA, I still use my own backline. I don’t know what the Helix does, but the AxeFX front panel has separate volume knobs for backline and PA. With an on-stage speaker my guitar is more lively. Sustain comes from the AxeFX settings, but there’s always a cabinet there if I want to provoke feedback. The backline also means that anyone dancing directly in front of the stage, and out of the PA’s line of fire, can still hear the guitar clearly.
  • Danny1969Danny1969 Frets: 10414
    I use the Pod Go and IEM's in a professional tribute band, we don't use any guitar or bass amps it's all direct into PA. The Pod Go has the same amp models as the Helix and many of the same effects. It doesn't have the same amount of IO but that's not something I or most people need in a live environment.  I use around 5 different banks each containing clean, crunch, solo and harmonized thirds patch's.
    The Pod Go then is fed to a stereo Radial transformer DI and fed into the desk in stereo.
    For decent in-ear mixes you need a  stereo source from the mixer such as 2 aux channels, one for left and one for right. Then you need some means of controlling that mix. Then you need some means of getting that mix amplified with a headphone amp and sent to your ears.
    Generally most bands now use a digital desk of some kind which has enough aux sends for IEM's to have individual mixes. Then there's always an ap you can run on your phone that can control your iEM mix.
    Then you either use an IEM transmitter and receiver or you can use a simple headphone amp on the floor and run the IEM signal up alongside your guitar cable or use a proper built combiner cable like this one
    Playing pure with IEM's with no backline can take a bit of getting used to and if you want to enjoy a decent experience then my tips are :-1:
    Either go full on expensive Sennheiser G3  / G4 transmitter and receiver or use a combiner cable. Cheap IEM radio systems are rubbish and prone to noise. If you guitar isn't wireless then just use a combiner cable anyway as radio IEM's are pointless if the guitar isn't wireless.
    Use stereo feeds and pan the band in your ears. The human brain can better separate frequencies if they are spaced apart in the stereo field and it sounds a lot better. This is why nobody mixes a record in mono
    A couple of boundry mics on the floor either side of the stage can add in some ambience and vibe to your ear mix. Doesn't need much, just a little but it makes all the difference.
    When setting up and sline checking use an open backed pair of cans rather than iEM's. That way you can monitor your guitar but still hear what's going on around you. Change to full on IEM's for the actual soundcheck songs though.
  • FWIW, I used Danny1969's posts on this in the past to build a new wired IEM setup (thanks Danny!) for my Quad Cortex. I couldn't be happier with this - a stereo IEM mix comes back from our desk (RCF M18), runs through my Quad Cortex (so I make quick volume adjustments), out of the QC's headphone out into my dual guitar/headphone cable, and from there into my IEMs.
    I used to run a wireless Shure PSM300 IEM kit - it's taken a bit of getting used to being on a cable again, but the difference in having a stereo IEM setup is well worth it. I did my first gig with this setup a couple of weeks ago and it was spot on.
  • CaseOfAceCaseOfAce Frets: 1346
    10 piece funk / rock band.
    Crikey - I can't imagine trying to find a place with guitar in the mix with that. Yikes.
    Genuine question - do you think anybody else is going to hear tremolo or compression or even a delay on the guitar signal whilst a horn section is blaring away with drums and bass thundering in the background?
    If it were me I'd be keeping it as simple as I could as regards guitar. I don't envy you this situation.
  • Some interesting thoughts... and thanks @Roland and @Danny1969 - there is a lot to think about there.
    The good news is, the band has all of the gear already and have been playing with IEMs for 5 years, so the setup is good and I know they already have a digital desk to provide each member with individual mixes.. just trying to figure out how I can get this working for me as this particular way is new to me.
    CaseOfAce said: 10 piece funk / rock band.
    If it were me I'd be keeping it as simple as I could as regards guitar. I don't envy you this situation. The word is space. 10 people in a band does not equal 10 people playing all the time (or at least I hope not)
    Clearly, there is no need for me to be doing much when everyone is engaged, at those points the horns will be doing their thing and I need to provide space to them. I have a lot of very rhythmic, quite minimalist work to do, lots of popping, diads and triads going on. however, they have some rockier songs in the set list where it is really just a 3 piece at points playing and the guitar has lots of space to work in.
    The audition sent chills down my spine when all the horns kicked in, it just sounds immense. I've always wanted to play in a band with full on horns :) Will slowly see if I can get some mighty, mighty boss tones in the set :)
    Have you considered a Fender Tonemaster (deluxe reverb etc). Yes - they are pricey - but just take a line out from the back of one to the mixing desk / PA and you've still got an amp on stage for monitoring. It would be a lot simpler then going down the modelling unit too.?
  • How about using your current amp with a Two Notes Captor X?
  • Unless your band setup is very conservative and your bandmates predictable then ANY system of IEMs should include a limiter. Otherwise you could very easily cause irreparable damage to your hearing.
  • @shufflebeat Good shout, I will ask them.
  • John_AJohn_A Frets: 3775
    horns are ace to play with.  Also, most horn players are very professional so if the guitarist has an important part to play they wouldn’t be blaring over the top of it, likewise a good drummer and bassist shouldn’t be thundering unless required.
    Guitarists however!
  • mike257mike257 Frets: 374
    If they're running a mixer capable of providing 10 independent mixes, it'll definitely be sophisticated enough to have dynamic processing on those outputs, so slapping a limiter across it should be a trivial task.
  • JotaJota Frets: 464
    edited November 2021
    In 2019 I joined a band and had a similar problem.
    Got myself an HX Stomp and I'm pretty happy with it.
    It's my all around FX thing when I use my real amps and it's my whole rig when I'm not using real amps.
    An aux dual switch and a small MIDI switcher can add a lot of options to the unit without going full on big MIDI switcher.
  • StratavariousStratavarious Frets: 3676
    My Marshall can run silent using the emulated out to the desk or I use it at modest volume as a monitor and I have a Boss GT as my other DI option.
    +1 on some ambient mic to your Aux mix. It can sound really isolating without.
  • I've ordered a set of ACS's 'Ambient' vented IEMs - theory being that they let in a little ambient sound and reduce the occluded/isolated experience. Will report back on how they turn out, should be getting them next week.
