Anyone got one of these? I need a new iron as my old trusty Weller is knackered. I like the compact formfactor and temp control without having a chunky solder station. I've seen this recommended by a bunch of people but not guitar folks as far as I can see. I generally need it for a few pedals a year and the occasional bit of guitar rewiring. I'd certainly consider another amp build in future but it's not critical to a decision on a soldering iron.
What say ye, forum wisdom?
https://hackaday.com/2017/07/24/review-ts100-soldering-iron/
What's up with your Weller ? they are generally pretty easy to fix
The Weller is eating tips to the point the thread is starting to get corroded. I've always assumed it's because the voltage in AD is a little higher than the UK so it gets a bit overheated. In any case I want something temp-controlled and will keep the weller as backup
There is also (obviously) and element of wanting a new toy to make my life easier because I've run out of tips and have at least 6 pretty pedal enclosures that need circuits to go in them
https://thepihut.com/products/adjustable-60w-pen-style-soldering-iron-220vac-uk-plug?variant=12364079464510¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQjw8p2MBhCiARIsADDUFVFP7hc6qSAscZMTdktP64xRzxcdd-tw_Wtfw-zkifVTHSazy7SYAZ4aAnvNEALw_wcB
With a suitable PSU and fat tip I think it would be up to doing the back of pots.
Overall package via amazon. I have another cable with the proper plug on it. The iron itself is in that tiny box - it's really dinky!
And in hand. Lightweight but feels sturdy. And it will be a little heavier once it's got a cable attached. Further thoughts to follow once I've used it a bit.
