So I've bought (very cheaply) an Orange Crush 15r, the power switch is stuck (in the off position) so thats a relatively easy fix. Its also got a hardwired power cable which I'm not a fan off. So i plan to fit a panel mount IEC socket like this
https://uk.rs-online.com/web/p/iec-connectors/0488191 ( to save clicking, that one is 10a 250v, panel mount with 2 screws)
I've built pedals, done some rudimentary home wiring so i'm fairly confident but I was always told to ask someone who may know better before doing anything you are even 1% uncertain about. So to allay any nagging doubts I may have, are there any pitfalls to my plan?
I did think of fitting a jack output to run the amp to my cab but I'll prob not do that (unless I find a switched socket on RS somewhere)
ta in advance
A switched speaker jack is a very easy mod, just make sure you use a plastic-bodied jack so it doesn't short to the chassis.
There’s no reason you can’t fit an IEC socket. I would be inclined to go through the wood rather than the metal back panel - much easier to cut. If you make a neat tight job of the hole and screw it firmly to the wood it will be safe. You should in theory have it PAT tested, but if you know what you’re doing there’s no real risk.
You could also fit a speaker jack through the wood but you’ll need to cut a bigger hole and put a jack plate over it, the panel will be too thick for it without one. If you can drill the metal it’s probably easier.
