Hi all, I'm looking to rewire my guitar and have a few extra options to try out. I have a 5 way super switch and a push pull pot. i haven't used one of these super switches before and I'm a little confused, the options I want are
(push pull down)
1. Bridge humbucker
2. Bridge and Neck screw coils
3. Bridge and Neck humbuckers
4. Neck humbucker Parallel
5. Neck humbucker series
(push pull up)
1. bridge split
2. Bridge Parallel
3. *
4. Bridge and Neck slug coils
5. Neck split
can anyone help me out with this or point me towards a more reasonable solution? I don't mind losing a few options as it's probably pretty overkill. cheers
The bridge humbucker with coils in parallel is one of the options in a circuit I associate with early Paul Gilbert.
The push-pull pot can only help if it served as a mode switch. It would be necessary to create each "bank" of sounds on one half of the switch. I'm not sure that that is physically possible.
Normally, two poles determine when each humbucker is in circuit. A third pole automates the series/parallel mode switching of the neck humbucker.
I am not saying that your proposed circuit is impossible. I am suggesting that even @ICBM will balk at sussing it out.
