SOLD
Duppy03Duppy03 Frets: 104
edited September 2013 in FX £
In like new condition with original box, instructions and sticker £55.
I'm guessing it would be around the £5 mark to post.
  • Duppy03Duppy03 Frets: 104
    Full details and spec:
    True bypass ABY amp selector with tuner out
    On-board transformer to eliminate ground buzz
    180° polarity reverse to phase-match amps
    Compact and rugged for pedalboards
    Plug and play easy to use
    Designed for the purist, the Radial BigShot ABY is an ultra compact, 100% passive foot switch that provides true bypass ABY amp switching capabilities with A or B toggle and A + B combine functionality. This assures the guitar signal is routed directly to the amp without any buffering, loading or tone altering circuits.
    To add versatility, the BigShot ABY has a built-in transformer that can be engaged to eliminate troublesome ground loops. Once on, you can also ensure your two amps are properly in phase using the 180º polarity reverse switch.
    The compact yet ultra rugged design makes the BigShot ABY ideal for pedalboard designs where space is always at a premium. Furthermore, because it does not require powering to make it work, it eliminates the need for batteries and space hungry power supplies.
