You've cleaned the outside. It is probably worthwhile doing the same inside. Remove any dust, grime or cobwebs. Check for dry/cold solder joints. Squirt electrolube into the pots and sliders.
Your photograph reminded me that my Squier VM Jazz Bass is still on seemingly permanent loan to my brother.
Just played that Squire fretless through it today and it was faultless.
It's essentially a Marshall BassState built in India - or Indonesia, I forget which for this series.
If there is anything wrong with it, it's fixable - they're very simple analogue technology and pretty easy to work on as well. The worst case is a blown speaker, but even replacing that should be less than the cost of almost any other amp.
Did you have them removed?
I didn't realise it was a lined fretless. I was referring to dots on the face of the fretboard, not along the edge of the neck.
It looks like a fretted bass.
