Jackson Pro Series Soloist SL3M In Rainbow Crackle
jemstar555jemstar555 Frets: 87
edited December 2021 in Guitars £
Stunning guitar but I have too many superstrats and some have to go.
Looking at £750 but would consider trades for amps/guitars/effects ...
https://ibb.co/jzgxHdX
Body
• Body Shape: Soloist
• Body Material: Basswood
• Body Finish: Gloss Color Matched
Neck
• Neck Material: Maple
• Neck Construction: Neck-Through-Body with Graphite Reinforcement and Scarf Joint
• Neck Finish: Gloss Color Matched
• Fingerboard: Maple, 12”-16” Compound Radius (304.8 mm to 406.4 mm)
• Frets: 24, Jumbo
• Position Inlays: Black Piranha Tooth (Small Sharkfin)
• Nut (Material/Width): Floyd Rose 1000 Series Locking, 1.6875” (42.86 mm)
• Headstock: Jackson Pointed 6-In-Line
• Tuning Machines: Jackson Sealed Die-Cast
• Scale Length: 25.5” (648 mm)
Hardware & Electronics
• Bridge: Floyd Rose 1000 Series Double-Locking Tremolo (Recessed)
• Bridge Pickup: Seymour Duncan Distortion TB-6
• Middle Pickup: Seymour Duncan Custom Flat Strat SSL-6 RWRP Single-Coil
• Neck Pickup: Seymour Duncan Custom Flat Strat SSL-6 Single-Coil
• Pickup Switching: 5-Position Blade: Position 1. Bridge Pickup, Position 2. Inner Coil of Bridge and Middle Pickup, Position 3. Neck and Bridge Outer Coil, Position 4. Neck and Middle Pickup, Position 5. Neck Pickup
• Controls: Volume, Tone
• Control Knobs: Dome-Style
• Hardware Finish: Black
• Strings: Nickel Plated Steel (.009-.042 Gauges
