Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I'm not certain, but I might have marked what I changed them from (hi-tech expedient of a marker). I have to sign off for the night now but bump this tomorrow to remind me and I'll take a look. Worst case scenario I can show you the setting I use which (I think
I'm going on memory here (I did this months ago), I think what I did was I put the marker mark at where 12 o'clock would have been with the stock setting. So I moved the top trim pot (Q of yellow inductor, according to the manual) to ~1 o'clock, the middle trim pot (Q of red inductor) to ~12:30pm and the bottom trim pot (gain/volume) to 11'o'clock. (Just in case you can't see the ink mark, was a bit low on light and had to use the flash.)
I think that's what I did. Assuming I'm remembering correctly. And assuming they were set to the stock factory setting when I got it. If I remember correctly I didn't want just as big a difference between the two inductor tones, and also the gain was set a bit low.
Now that I think of that, that doesn't make sense. I thought I turned the gain up and that sounds like I turned it down.
Can't help with the question though Sam! I've got the Dunlop 535Q recently and I'm really enjoying it.
That's a good idea about the boost. Yeah I was wondering if, since I prefer the tone with the boost on, I should just turn the boost down to unity gain (or near enough) and use it like that. Might be worth a try.
And yeah, as I said, in stock form the red inductor was very dark and the yellow very bright. IIRC I brightened up the red and darkened the yellow slightly (still sounds more or less crybaby, just slightly sweeter), and they sound a lot better. Still sound very different, but now it's two different but very useful tones, as opposed to almost different for the sake of it to try to sell the pedal as "super-versatile".
