Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
To fix it you’ll need to pull it backwards and downwards, then glue a brace under the top across the soundhole just forward of the neck - unless there’s one there already (most normal acoustics have one) in which case it’s either come off or broken and needs to be reglued or replaced.
You could probably hide the damage with a large soundhole pickup, which would almost certainly sound a lot better than the awful piezo system these come with… I’m sure I’ve seen a pro using one like that, but I can’t remember who.
Let me get this straight - so clamp the body down (red) and apply force downwards (blue) - is that correct?
https://i.imgur.com/3J4TDwX.jpg
This is the first Strata/Telecoustic I’ve seen broken like this, but it used to be very common with the cheap shallow-body Ovation copies (Encore etc) in the 80s, sometimes even without being dropped.
Most repairers would probably write off something cheap like this, but I know you like a challenge .
Instagram
Re. action - when it arrived, it was shimmed to get it playable.
Looking on a full screen now not a phone...
How much area is there under the unbroken sides of the top and above the sides of the neck block? Gluing those areas very thoroughly might give enough reinforcement even if there isn't a brace across the top.
The most remarkable thing I've noticed, which I really didn't expect, is that it's a solid top - I always assumed they were ply given the cheapness and bright/tinny sound they have.
I was surprised too - It even looks like a good grade from the little bit we can see. Near perfect quartersawn and roughly 20 grain lines per inch
Instagram
https://www.thefretboard.co.uk/discussion/219350/is-repair-possible#latest
It's a very nasty break and a professional luthier isn't likely to take it on - it looks like some sort of lower-end Fender acoustic - but with some care and the right type of (normally completely inappropriate!) glue it might be salvageable as a DIY job.
When H7 goes to sleep, all of his gear goes to sleep.
