It’s rarely critical to the answer, but it would make it a lot easier to be sure.
If it adds the extension speaker then it’s necessary to know if it switches the impedance of the amp - some do, many don’t.
*In general* a mismatch of up to 2:1 in either direction is safe with a valve amp, but there are some exceptions and it might be important to know whether it’s a good idea to push it close to the limit.
From the manual:
Interested to know is there any box/gizmo/thing to add in line with the speaker via speaker cable(s) to convert the impedance from 8ohms to 16ohms?
Are you going to be playing it loud? If you’re not cranking it into power-stage overdrive it's fine anyway, impedance matching isn’t at all critical.
There is a way of testing this even if the manual doesn’t say. Turn the amp up loud enough so you can hear the background noise/hiss - no guitar signal. Then put an unconnected speaker cable into the extension jack. If the noise stops, the extension speaker turns off the internal one. If it doesn’t stop and there is a brief interruption as the plug goes in or out, or a small change in the volume of the noise, it’s switching the impedance. If it doesn’t do either, it’s simply in parallel.
Have a great Christmas.
Bandcamp
Spotify, Apple et al
