Pedalsnake - 7-channel, 24 foot - Pedalboard cabling solution
Perfect solution for complex wiring systems. I just won't be using such a system soon so this is redundant! Basically, the ideal solution for having some effects in the loop, some in front and keep power all together. Means you can run one single cable to your pedal board!
It's the top end 7-channel, 24 foot version. Great condition, only 3 months old. I have a few pigtails too - 6 1/4" jack ends, and the appropriate ends for 2 9V pedals to be powered on their separate wallwarts.
Only 'issue' is that the black connector at the amp end has a slightly dented case but it fits perfectly into it's slot. Not even sure how it happened! Will provide pictures if anyone needs them.
I paid £170 for this lot in June but willing to let it go for £100 plus postage?
Feedback
