I have a new screen - a lovely 4K 32 inch jobbie, and I also have a 27 inch mounted portrait for easier document review.
But the portrait one currently forces one of my Yamaha HS7 speakers to be partially behind it - blocking a woofer completely I can move the screen out of the way when mixing (the screen is on an articulated arm) but it's still a bit annoying.
The woofer in the speakers is currently level with the top of my head (when the screen isn't in the way!) If I raise them (there's 1 more slot available on the stands) then they will be firing right over the top of my head, and the screen will still cover the bottom third of the woofer.
I'm thinking about wall mounting the speakers instead, and having them angled downwards.
Is mounting them downward pointing a bit a problem at all? Assuming my wall will take the weight anyway!
ta
This is how I have my studio monitors in the room:
Mix position is 38% along the length of the long wall, the monitors are positioned so the tweeter is at ear height and the monitors are 30 degrees along the centre line.
There might be good reasons for diverging from this in your situation and that might come with a performance cost.
I would tend to not want to wall mount, but it depends on the room.
I dislike multiple monitors as it takes me away from looking right at the middle between the monitors.
Maybe a photo of things in situ will help?
