Specifications
Model Name: Gibson Custom 58 Les Paul Standard BOTB Pg 24 VOS Code: LPR58M2M15697
Body
Neck and Fingerboard
Neck: Mahogany
Nut Width: 1.687"
Fingerboard: Indian Rosewood Frets: Historic Gibson Narrow/Tall Scale Length: 24.75" / 628.65mm Number of Frets: 22, 1959 Reissue
Hardware and Electronics
Bridge: ABR-1 Non Wire
Tailpiece: Light Weight w/ Long Stud, Anchor Nut: Nylon
Knobs: True Historic Gold Top Hats Machineheads: Kluson Reissue
Plating: Nickel
Bridge Pickup: Custombucker (Unpotted) Neck pickup: Custombucker (Unpotted)Hardware Material: Aged Nickel
Miscellaneous
Included: GWW Hard Shell Case, Gibson TH R9 Pickguard, Certificate of Authenticity Booklet
Series: Gibson Custom Shop
Material: Mahogany w/ Hand-Picked Top Finish: BOTB Pg 24 VOS
GLWTS
@DB1 very kind words, are you sure you don't need this in your life?
