Any tips for stuck saddle screw?
I have a screw on my low E saddle that won't budge and it needs raising. Any tips or recommendations?
  • RolandRoland Frets: 9127
    Penetrating oil
  • Roland said:
    Penetrating oil
    Got it sitting in a lid of WD40 for the night to see how that goes..
  • ICBMICBM Frets: 74475
    If it's really stuck and penetrating oil doesn't help, remove the saddle and grab the screw from underneath with some pliers - you're best to use them end-on so the serrations in the jaws match the thread grooves if you can, to limit the damage - and wind it out downwards. If either the thread or the Allen socket are too chewed up to re-use, you can replace it.
  • SteveRobinsonSteveRobinson Frets: 7343
    edited January 2022 tFB Trader
    A bit of heat helps loosen them too. I use the gas hob.
    Edit: remove it from the bridge first obvs!
  • Going to try both those if it doesn't budge tomorrow :+1:
  • thermionicthermionic Frets: 10019
    Roland said:
    Penetrating oil
    WD40 is not penetrating oil…
    It might well work, but there are better products, like PlusGas.
  • ZoolooterZoolooter Frets: 897
    edited January 2022
    Spray a bit of PlusGas on but leave for 24 hours then try to loosen it.
  • SargeSarge Frets: 2436
    try a soldering iron on the saddle, not the screw. it should expand a tiny bit and might be enough to get the screw shifted
    Good old pliers did the trick :+1:
