I have a windows computer atm running reaper, which i started getting in to just before covid hit.
Being a cheapskate,and owning an adequate windows computer,reaper seemed like a good choice (and it is) but......
All my friends have Logic,or Protools,and when i get stuck with something,which is quite often the case,im a bit in the dark,as im not very DAW savvy.
So im looking to change my computer to an Apple (Secondhand preferably)
As one ill have a lot more help if needed,and my friends say that logic is easier to navigate.
My question is,twofold
1) Do you think this would be a good move, (besides being an expensive one)
im having really good fun writing tunes,and recording them, but progress is slow,and daunting at times because of my lack of knowledge,and my friends do help, but are not familiar with Reaper.
2) what system would you get CPU,ot laptop ?
What system do you guys use ?
I have been advised to get an Apple tower,(iMac ?) rather than a laptop ?
What sort of memory would i need to run Logic,and plugins too.
Thanks in advance
Ebay mark7777_1
All projects can be worked on, across any software or platform, if you work with audio stems.
Logic and PT are deep money pits to have working well, and in a few months, when you have got more comfortable with the concepts, your friends will be using Reaper too I suspect, so many things are possible that are not easily done in other DAWS, mainly to do with making it do what you want, and not being forced into a workflow that you have to learn.
Feel free to ask here if you need any further info, and have a look on YT for Kenny's vids to get you going quickly.
Also, it'll make your knowledge much more transferable to other DAWs, should you ever want to change.
