I'm not up to speed with precision pickups and I'm not entirely sure what I want from them other than good "tight" bass and some zing if possible.
one thing I'd like to be able to get is the tone from the Zero7 remix of N.E.R.D - Provider.
I've got close with the jazz pickups in my Westone Thunder ii, but hoping a pbass would get closer.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
Right now, on eBay, there is a listing for a pre-owned Seymour Duncan SPB-2 Hot pickup that may be within budget. There is also one for an Antiquity II model. (Over budget but worth every penny.)
Irongear and Alegree Old Timer should have something suitable at modest cost.
Depending on the brand and model, it might be possible to cut through the resin without damaging the internals. (I have done this to Seymour Duncan Active EQ and Pro Active bass pickups.) Much depends on how generous the manufacturer has been with the resin.
Bartolini pickups are resin potted but have soldering tags protruding. Kent Armstrong/SKY pickups are pretty darned impenetrable.
I do this. It helps when restoring a modified instrument to stock specifications prior to selling it on.
The difference is that I do not then attempt to pass the stock pickup off as the item described on the packaging.
UPDATE: Listing reported. HTH.
He has tried to remedy the issue, but blah blah blah.
I've reported the listing, it would be helpful if others did too
I don't want a negative mark against my account.
I ordered the Tonerider from nw guitars as it is time to start assembly.
