I'm using an Akai EIE Pro and I'm new to all of this. I want to use Cakewalk as my DAW but it won't let me set my Asus Xonar Essence as the output as the Akai is selected there. My Xonar is listed but pale grey and won't let me select. I have a feeling that this is the Akai driver being a bully here.
However, if I use Audacity, I can set Akai input and Xonar output and it works.
I have zero experience of using a DAW and think I'd prefer to use Cakewalk. Does anyone know a solution to the problem I've listed above please?
It may be that I don't know what I'm talking about???
Cakewalk allows the use of one soundcard when using an ASIO driver.
https://www.cakewalk.com/Documentation?product=Cakewalk&language=3&help=AudioPerformance.18.html
Unsure about Audacity. What drivers are you using there?
The opening screen of Audacity allows choice of input and output separately on two drop-down boxes. The selections remain visible on screen. I guess this must be using the Akai and Xonar drivers respectively.
I'm pretty sure it has some routing options in there that allow different I'O, its a bit clunky, but I am using it on an Asus Win 10 Zenbook.
Pretty sure it helped me out in the past.
First, start with this.
https://www.sweetwater.com/sweetcare/articles/roland-difference-between-asio-wdm-mme-drivers/
Cakewalk will be using the Akai ASIO driver. Audacity will be using something else. Have a look within Audacity to see which.
So you only need to use the Akai as your soundcard. Or are there features on the Xonar you want to make use of?
My wanting to record is purely a hobby thing, nothing too serious. I have a Drumbrute, keyboard, bass and I'd rather play my Tele than watch the telly. So just a bit of fun really.
Does anyone know if Reaper will allow the Akai as the input and the Xonar as the output please?
Costs nothing to try, but I think you can only ever use a single device at a time, which is why I suggested a clunky software solution like Asio4all, which does let you mix I/O devices.
Either of these solutions cost £0 to try, I'd have to buy the same devices as you to advise further.
Good luck.
Whilst Audacity is basic and lacks some functionality of the others, I have concluded that it probably meets my needs for a simple recording and editing function. I'm sure it'll be easier to learn to use too.
I use Audacity too, but mainly just for auditioning audio, and don't think I would even attempt to use it as a true audio production tool.
There is much to learn, and I have tried most of the other DAWs, nothing comes close to Reaper for usability or flexibility, IMO.
Some very clever stuff goes on in the background of all DAWs, but I think Cockos have got the balance right, it doesn't insist on the installation of a lot of stuff that will never be used, but allows pretty much anything to be done.
Once you have tried a few projects, in various things, just try comparing load times, and updates for an example of how much time can be saved with Reaper, once you have got a grip on it.
My Akai has a headphone socket so I can use that to monitor recording then connect to my speakers for editing.
This is not a serious project for me, just a bit of fun. I think I'm going to enjoy experimenting. Thanks again.
This will all start to make sense when you get a bit more used to the work flow, sometimes starting with an empty project seems very daunting, set yourself a few goals as you get further into it, and use it as a platform to move on.
If you get stuck, feel free to ask here, but Kenny's vids are excellent, and it's worth visiting the Reaper forum, lots of info there.
Thanks again.
Have look at getting SWS extensions, and Reapack installed too, there are many cool features added.
Basically, all you do is add some stuff to your Reaper install folder, but check them out first.
You should have a look at some of the videos on default settings too, timebase, having backup folders etc, but it sounds like you are on the right track anyway.
good luck.
