https://ergodebooks.com/?route=product/product&product_id=2457249¤cy=GBP
And where are you now? Show us a vid
The biggest fault I see inexperienced musicians do is slowing down on the hard bits and speeding up on the easy bits. People notice rhythm more than anything so if you do a fast run miss or flub a few note and come in on time at the next bar it's much less jarring to a listener than slowing down.
I find metronomes annoying and unnatural so use a basic drum machine. Some practice amps have them built in or there are phone apps etc.
Two exercises I did when learning drums I've adapted for guitar which were super helpful were
Rhythmic displacement
Do 16th note mutes with up and down picking
Count along with the notes "1 e & a 2" etc
and then do a chord stab on each note in turn so first bar on the one, second bar on the "a" of one then the "&" of one etc until you've learned how to consistently nail every beat.
Make sure anything that's on the off beat is always and upstroke and anything on an on beat is a downstroke.
Note Pulses
Again muted picking on one string.
Play 1/4 notes for one bar 1/4 note triplets then 1/8th notes then 1/8th note triplets then 16th notes.
Take 8 quavers in a 4 beat bar
start off with playing / strumming sets of 8 in time (preferably down up .. rather than down down down ..)
then start placing a series of rests (ie don’t play) the e.g. 2 4 6 8 beats
then rests on the 1 3 5 7
then rests on 2 and 5
etc
try and keep using the down up down up irrespective of which rests are being used
There are books which provide lots of these rhythms, including which rests are used in different genres - it looks like I loaned my one out and haven’t got it back
So start with basic understanding of subdividing different rhythm values, whole/half/quarter/eighth/sixteenth et and make sure you can play those with a metronome/drum machine in time so the tempo doesn't need to change or anything.
I use a textbook once called the Encyclopaedia of Reading Rhythms. It has several counting exercises which really helped me tidy up my rhythm notation reading.
Rhythm makes up for 90-95% of guitar playing so its important its good!
Your rhythm playing will improve overnight.
Other than that - metronome - in countless music rooms / man caves I see racks upon racks of guitars, amps, effects pedals -
and not a single one of these things in sight...
These are things which will develop your own innate sense of time, rather than just enable you to follow a rhythm and not sound discernibly out of time with it.
