Should cavity screening be earthed when using EMG pickups
I have a partscaster, the body cavity is mostly shielded with adhesive-backed aluminium foil
The earth on the EMG set that was in it was connected to the shielding
I have fitted a new EMG set, but left the shielding unconnected (NB: it may have connection via the shielding on the scratchplate anyway)
Should shielding be earthed when using EMGs?
  • ICBMICBM Frets: 74475
    Ideally, yes. But you could compare the noise levels with and without, and not bother if there's no difference. Although bear in mind that this varies with location and noise sources...
    Although EMGs are very well-shielded as far as the controls, the tone caps and a couple of the other bits of wiring aren't, and it's much worse if you use the solderless kits since there's far more unnecessary cable length (another reason I dislike them).
    If the shielding is grounded via the pots and the pickguard shielding then it's a moot point anyway.
